Schémas Haute tension
Voici un exemple :
Avant (doc Hager) :
Après avec LogEleec :
<svg width="782" height="460" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
 <g>
  <title>Calque 1</title>
  <image xlink:href="menus/HT/cellules/IM.png" id="svg_1" height="368" width="79" y="0" x="0"/>
  <image xlink:href="menus/HT/cellules/IM.png" id="svg_2" height="368" width="79" y="0" x="87"/>
  <image xlink:href="menus/HT/cellules/DM1-D.png" id="svg_3" height="368" width="158" y="0" x="181"/>
  <image xlink:href="menus/HT/cellules/GBC-A.png" id="svg_4" height="368" width="158" y="0" x="356"/>
  <image xlink:href="menus/HT/cellules/QM.png" id="svg_5" height="368" width="84" y="0" x="528"/>
  <image xlink:href="menus/HT/cellules/DM1-S.png" id="svg_6" height="368" width="158" y="0" x="624"/>
  <image xlink:href="menus/HT/cellules/DM1-S.png" id="svg_7" height="1" width="1" y="130" x="568"/>
  <image transform="rotate(-90 56.000000000000064,391.00000000000006) " xlink:href="menus/HT/recepteurs/Source.png" id="svg_8" height="22" width="18" y="380" x="47"/>
  <image transform="rotate(90 143.99999999999997,400.00000000000006) " id="svg_9" xlink:href="menus/HT/recepteurs/Source.png" height="22" width="18" y="389" x="135"/>
  <image xlink:href="menus/HT/recepteurs/transfo.png" id="svg_10" height="44" width="30" y="416" x="574"/>
  <image xlink:href="menus/HT/recepteurs/transfo.png" id="svg_11" height="44" width="30" y="402" x="706"/>
  <line id="svg_12" y2="52" x2="277.184853" y1="52" x1="58" stroke-width="5" stroke="#000000" fill="none"/>
  <line id="svg_13" y2="363.916811" x2="58" y1="388" x1="58" stroke-width="5" stroke="#000000" fill="none"/>
  <line id="svg_14" y2="361" x2="146" y1="395" x1="146" stroke-width="5" stroke="#000000" fill="none"/>
  <line id="svg_15" y2="418.00909" x2="589" y1="363" x1="589" stroke-width="5" stroke="#000000" fill="none"/>
  <line id="svg_16" y2="404.012818" x2="723" y1="365" x1="723" stroke-width="5" stroke="#000000" fill="none"/>
  <line id="svg_17" y2="366" x2="430.394915" y1="366" x1="277" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
  <line id="svg_18" y2="52" x2="723.638479" y1="52" x1="497" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
 </g>
</svg>
Re: Schémas Haute tension
tiens la ht ne marche plus :(
Revenir à « Schémas électriques »
