Voici le schéma :
► Afficher le texte
Code : Tout sélectionner
<svg width="1103" height="975" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
<g>
<title>Calque 1</title>
<image xlink:href="menus/industriel/alimentation/alimentation tri+N+T.png" id="svg_1" height="84" width="171" y="0" x="7"/>
<image xlink:href="menus/industriel/protection/sectionneur + contact precoupure.png" id="svg_2" height="212" width="117" y="144" x="0"/>
<image xlink:href="menus/industriel/commande/contacteur de puissance.png" id="svg_3" height="213" width="116" y="420" x="1"/>
<image xlink:href="menus/industriel/protection/relais thermique.png" id="svg_4" height="183" width="116" y="429" x="225"/>
<image xlink:href="menus/industriel/recepteur/moteur.png" id="svg_5" height="266" width="401" y="709" x="85"/>
<image xlink:href="menus/industriel/protection/disjoncteur Bipolaire.png" id="svg_6" height="198" width="85" y="158" x="421"/>
<image xlink:href="menus/industriel/alimentation/transformateur.png" id="svg_7" height="222" width="163" y="420" x="391"/>
<image xlink:href="menus/industriel/protection/disjoncteur uni+N.png" id="svg_8" height="198" width="44" y="715" x="570"/>
<line id="svg_9" y2="147.010001" x2="23" y1="70" x1="23" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_10" y2="149.010001" x2="59" y1="72" x1="59" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_11" y2="149.010001" x2="93" y1="72" x1="93" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_12" y2="431.191295" x2="25" y1="337" x1="25" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_13" y2="430.021975" x2="58" y1="339" x1="58" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_14" y2="429.0489" x2="92" y1="337" x1="92" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_15" y2="705.022469" x2="23" y1="616" x1="23" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_16" y2="682.088853" x2="60" y1="615" x1="60" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
<line id="svg_17" y2="659.092963" x2="95" y1="616" x1="95" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#000000" fill="none"/>
<line fill="none" stroke="#000000" stroke-width="5" x1="93" y1="658" x2="137.011362" y2="658" id="svg_18"/>
<line fill="none" stroke="#000000" stroke-width="5" x1="319" y1="439" x2="319" y2="357.9865" id="svg_19"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="135" y1="657" x2="135" y2="354.941367" id="svg_20"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="322.000007" y1="356" x2="134.826169" y2="356" id="svg_21"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="57" y1="680" x2="167.117863" y2="680" id="svg_22"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="21" y1="703" x2="203.002747" y2="703" id="svg_23"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="166" y1="681" x2="166" y2="379.78745" id="svg_24"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="199" y1="704" x2="199" y2="407.998311" id="svg_25"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="165.000003" y1="380" x2="279.593586" y2="380" id="svg_26"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="197" y1="409" x2="249.038447" y2="409" id="svg_27"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="278" y1="377" x2="278" y2="439.03225" id="svg_28"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="247" y1="406" x2="247" y2="445.051248" id="svg_29"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="246" y1="594" x2="246" y2="729.033329" id="svg_30"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="280" y1="595" x2="280" y2="721.015872" id="svg_31"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="318" y1="599" x2="318" y2="726.003937" id="svg_32"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="22" y1="95" x2="479.233807" y2="95" id="svg_33"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="58" y1="114" x2="441.81506" y2="114" id="svg_34"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="481" y1="173" x2="481" y2="93.975613" id="svg_35"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="440" y1="172" x2="440" y2="114.921107" id="svg_36"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="440" y1="340" x2="440" y2="480.057131" id="svg_37"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="479" y1="340" x2="479" y2="384.011362" id="svg_38"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="530" y1="480" x2="530" y2="383.994792" id="svg_39"/>
<line fill="none" stroke="#000000" stroke-width="5" stroke-linejoin="null" stroke-linecap="null" x1="477" y1="383" x2="532.036352" y2="383" id="svg_40"/>
<line id="svg_41" y2="698.004167" x2="456" y1="578" x1="456" stroke-width="5" stroke="#0000FF" fill="none"/>
<line id="svg_42" y2="693.985297" x2="582" y1="728" x1="582" stroke-width="5" stroke="#0000FF" fill="none"/>
<line id="svg_43" y2="696" x2="582.003906" y1="696" x1="454" stroke-width="5" stroke="#0000FF" fill="none"/>
<line id="svg_44" y2="657.057671" x2="528" y1="579" x1="528" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_45" y2="655" x2="602" y1="730" x1="602" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_46" y2="654" x2="602.154175" y1="654" x1="526" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_47" y2="897.983875" x2="602" y1="929" x1="602" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<image xlink:href="menus/industriel/protection/sectionneur + contact precoupure.png" id="svg_48" height="212" width="117" y="100" x="711"/>
<image xlink:href="menus/industriel/protection/relais thermique.png" id="svg_49" height="183" width="116" y="96" x="901"/>
<image xlink:href="menus/industriel/commande/BP ARU clef.png" id="svg_50" height="146" width="80" y="395" x="725"/>
<image xlink:href="menus/industriel/commande/BP arret O.png" id="svg_51" height="134" width="68" y="393" x="880"/>
<image xlink:href="menus/industriel/commande/BP marche I.png" id="svg_52" height="134" width="68" y="665" x="760"/>
<image xlink:href="menus/industriel/commande/contacteur de puissance.png" id="svg_53" height="213" width="116" y="625" x="987"/>
<line id="svg_54" y2="926" x2="669.063352" y1="926" x1="598" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_55" y2="172.995836" x2="666" y1="926" x1="666" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_56" y2="169.026298" x2="786" y1="150" x1="786" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_57" y2="172" x2="788" y1="172" x1="664" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_58" y2="174.07681" x2="809" y1="148" x1="809" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_59" y2="171" x2="865.034473" y1="171" x1="807" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_60" y2="228" x2="864" y1="169" x1="864" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_61" y2="227" x2="979.038455" y1="227" x1="862" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_62" y2="210.88923" x2="979" y1="229" x1="979" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_63" y2="225.317821" x2="1002" y1="211" x1="1002" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_64" y2="226" x2="1042.048752" y1="226" x1="1001" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_65" y2="346" x2="1039" y1="224" x1="1039" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_66" y2="343" x2="704.665345" y1="343" x1="1041" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_67" y2="562.182358" x2="708" y1="340" x1="708" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_68" y2="559" x2="751.177428" y1="559" x1="706" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_69" y2="530.557075" x2="749" y1="559" x1="749" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_70" y2="562.014703" x2="782" y1="528" x1="782" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_71" y2="562" x2="901.016666" y1="562" x1="781" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_72" y2="513.906341" x2="898" y1="562" x1="898" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_73" y2="678.007485" x2="932" y1="515" x1="932" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_74" y2="837.055503" x2="775" y1="791" x1="775" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_75" y2="837" x2="719.991072" y1="837" x1="776" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_76" y2="616.94159" x2="721" y1="835.999994" x1="721" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_77" y2="617" x2="932.037732" y1="617" x1="720" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_78" y2="837" x2="808" y1="784" x1="808" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_79" y2="837" x2="963.114608" y1="837" x1="806" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_80" y2="725.781463" x2="960" y1="838" x1="960" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_81" y2="725" x2="1094.014598" y1="725" x1="957" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_82" y2="681" x2="1093" y1="726" x1="1093" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_83" y2="681" x2="928.960533" y1="681" x1="1043" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_84" y2="788" x2="957.908095" y1="788" x1="1045" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#FF0000" fill="none"/>
<line id="svg_85" y2="958.072239" x2="1092" y1="785" x1="1092" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
<line id="svg_86" y2="961.068148" x2="582" y1="900" x1="582" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
<line id="svg_87" y2="960" x2="581.996086" y1="960" x1="1093" stroke-linecap="null" stroke-linejoin="null" stroke-width="5" stroke="#0000FF" fill="none"/>
<text xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" id="svg_88" y="244" x="135" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">Q1</text>
<text xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" id="svg_89" y="543" x="110" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">KM1</text>
<text id="svg_90" xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" y="92" x="768" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">Q1</text>
<text id="svg_91" xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" y="621" x="1043" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">KM1</text>
<text xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" id="svg_92" y="540" x="355" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">F1</text>
<text id="svg_93" xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" y="94" x="957" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">F1</text>
<text xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" id="svg_94" y="425" x="768" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">S0</text>
<text xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" id="svg_95" y="421" x="917" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">S1</text>
<text xml:space="preserve" text-anchor="middle" font-family="serif" font-size="24" id="svg_96" y="692" x="791" stroke-linecap="null" stroke-linejoin="null" stroke-width="0" stroke="#0000FF" fill="#000000">S2</text>
</g>
</svg>
