IRL : platine va et vient + PC
A remercié : 57 fois
A été remercié : 80 fois
<svg width="714" height="1187" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
 <g>
  <title>Calque 1</title>
  <image transform="rotate(-179.3772430419922 111.18908691406249,421) " xlink:href="menus/branchement/Recepteurs/PLEXO hublot.png" id="svg_25" height="220" width="220" y="311" x="1.189087"/>
  <image id="svg_23" xlink:href="menus/branchement/Commandes/PLEXO inter SB.png" height="138" width="129" y="1047" x="563.189087"/>
  <image id="svg_21" xlink:href="menus/branchement/Platine/IRL vertical moyen.png" height="207" width="42" y="765" x="605.189087"/>
  <image xlink:href="menus/branchement/Commandes/PLEXO inter SB.png" id="svg_19" height="138" width="129" y="1048" x="50.189087"/>
  <image xlink:href="menus/branchement/Protections/Disjoncteur 16A.png" id="svg_1" height="217" width="48" y="94" x="260.189087"/>
  <image xlink:href="menus/branchement/Protections/Disjoncteur 20A.png" id="svg_5" height="217" width="48" y="94" x="313.189087"/>
  <image xlink:href="menus/branchement/Platine/tableau 2 modules.png" id="svg_3" height="407" width="125" y="0" x="249.189087"/>
  <image xlink:href="menus/branchement/Protections/Etiquette prise de courant.png" id="svg_4" height="45" width="46" y="272" x="313.189087"/>
  <image xlink:href="menus/branchement/Protections/Etiquette eclairage.png" id="svg_6" height="45" width="26" y="271" x="276.189087"/>
  <image xlink:href="menus/branchement/Platine/PLEXO boite de derivation 2.png" id="svg_8" height="244" width="238" y="608" x="252.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL vertical moyen.png" id="svg_7" height="207" width="42" y="407" x="290.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL horizontal petit.png" id="svg_9" height="42" width="75" y="648" x="183.189087"/>
  <image id="svg_10" xlink:href="menus/branchement/Platine/IRL horizontal petit.png" height="42" width="75" y="767" x="182.189087"/>
  <image id="svg_11" xlink:href="menus/branchement/Platine/IRL horizontal petit.png" height="42" width="75" y="707" x="484.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL vertical petit.png" id="svg_14" height="75" width="42" y="525" x="90.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL coude 1.png" id="svg_13" height="93" width="98" y="600" x="86.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL vertical moyen.png" id="svg_16" height="207" width="42" y="847" x="93.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL coude 2.png" id="svg_12" height="98" width="93" y="764" x="90.189087"/>
  <image id="svg_17" xlink:href="menus/branchement/Platine/IRL vertical moyen.png" height="207" width="42" y="846" x="289.189087"/>
  <image id="svg_18" xlink:href="menus/branchement/Platine/IRL vertical petit.png" height="75" width="42" y="538" x="409.189087"/>
  <image xlink:href="menus/branchement/Platine/IRL coude 3.png" id="svg_20" height="93" width="98" y="703" x="553.189087"/>
  <image id="svg_22" xlink:href="menus/branchement/Platine/IRL vertical moyen.png" height="207" width="42" y="846" x="605.189087"/>
  <image xlink:href="menus/branchement/Recepteurs/PLEXO prise de courant2.png" id="svg_24" height="138" width="129" y="1049" x="244.189087"/>
  <image transform="rotate(-89.49297332763672 603.1890869140623,467.9999999999999) " id="svg_26" xlink:href="menus/branchement/Recepteurs/PLEXO hublot.png" height="220" width="220" y="358" x="493.189087"/>
  <image id="svg_27" xlink:href="menus/branchement/Platine/IRL coude 2.png" height="98" width="93" y="443" x="407.189087"/>
 </g>
</svg>
Re: IRL : platine va et vient + PC
Je n'avais jamais remarqué, mais vous avez la possibilité dans le menu général de LogEleec d'accèder à une bibliothèque externe.
(a condition bien sûr de créé un compte)
Cela permet d'avoir toute sorte de dessin en format svg donc vectoriel.
Voici une idée :
Pas mal
Retourner vers « Schémas électriques »
